How to get CAD Structure
  • January 15, 2016
  • 4327 views
Hello friends,
I am looking for a query which can return me the CAD structure in windchill does some body know how we can achieve this. please see the screen shot
Best answer by BineshKumar1
SELECT DISTINCT A0B.name ParentName,
                A0B.documentNumber ParentNumber,
                A2B.name ChildName,
                A2B.documentNumber ChildNumber
FROM            EPMDocument A0,
                EPMDocumentMaster A0B,
                EPMDocumentMaster A1,
                EPMDocument A2,
                EPMDocumentMaster A2B,
                EPMMemberLink A3
WHERE           (A0.idA3masterReference=A0B.idA2A2)
AND             (A2.idA3masterReference=A2B.idA2A2)
AND              ((A0B.name = 'ER00020039.asm'))
AND             ((A3.idA3B5 = A1.idA2A2)
AND              (A3.idA3A5 = A0.idA2A2)
AND           (A2.idA3masterReference = A1.idA2A2));
Try this. It worked on my system to get level 1 CAD structure.
Thank you
Binesh Kumar
User epmmemberlink table to connect two epmdocuments. If you are looking for reference documents, use epmreference table
Thank you,
Binesh
adev1-VisitorAuthor
Hi Binesh,
I try this but seems like not getting the accurate result
SELECT    dM2.DOCUMENTNUMBER AS ASSEMBLY, M1.DOCUMENTNUMBER AS COMPONENT
FROM      EPMDOCUMENT, EPMDOCUMENTMASTER M2, EPMMEMBERLINK, EPMDOCUMENTMASTER M1
WHERE       EPMMEMBERLINK.IDA3B5 = M1.IDA2A2
                   and M2.DOCUMENTNUMBER = 'W10805805_CP01.PRT'
                   and EPMDOCUMENT.IDA3MASTERREFERENCE = M1.IDA2A2
GROUP BY  M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER
order by  M2.DOCUMENTNUMBER, M1.DOCUMENTNUMBER;
adev1-VisitorAuthor
nup it did not workout gives null values
