Hi Everyone,
Good Morning.
I know there is one utility which will help us to get all soft attributes attached with it for a given soft type.
Can you please help me in getting the URL for the same?
Thanks in advance.
Best Regards,
John
Hi @jselvaraj,
I hope you must be looking at http://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=WC_WebjectLib_DescribeAttr&action=show
Below is the example I created for this:
<%@page language="java" session="false"%>
<%@page access="http"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
String instance = wt.util.WTProperties.getLocalProperties().getProperty("wt.federation.ie.VMName");
System.out.println("*** Instance -> " + instance);
<ie:webject name="Describe-Attributes" type="OBJ">
<ie:param name="INSTANCE" data="<%=instance%>"/>
<ie:param name="ATTRIBUTE" data="$(@form[0]attribute[0])" delim=","/>
<ie:param name="INCLUDE_SOFT_ATTRIBUTES" data="true"/>
<ie:param name="INCLUDE_DESCRIPTORS" data="true" />
<ie:param name="INCLUDE_ATTRIBUTES_FROM_SOURCE" data="SURFACE"/>
<ie:param name="TYPE" data="wt.part.WTPart"/>
</ie:webject>
I hope it helps you.
Shirish
Here are some references for you:
https://www.ptc.com/en/support/article?n=CS97049
https://www.ptc.com/en/support/article?n=CS59855
Shirish
