We are happy to announce the new Windchill Customization board! Learn more.
How to get all Attributes of WTObject..?
RS_10128209
I want to get all attribute Internal name which are related to WTPart or WTDocument
9 REPLIES 9
Take a look at this article
Marco
Thanks @Marco_Tosin
Plz help me with any API or programatic solution
Hi @RS_10128209
the API does not exists or I don't know it.
You need to write code to find TypeDefinition and then get attribute list.
Here is a code for you that can work. Just define soft type internal name and it returns what you need.
For me it works
try
String typeName = "wt.epm.EPMDocument";
QuerySpec queryspec;
queryspec = new QuerySpec();
int idLWCObject = queryspec.appendClassList(LWCTypeDefinition.class, true);
CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
andCondition.append(new SearchCondition(LWCTypeDefinition.class, LWCTypeDefinition.NAME, SearchCondition.LIKE, typeName), new int[]{idLWCObject});
queryspec.appendWhere(andCondition, new int[]{idLWCObject, idLWCObject});
queryspec.appendOrderBy(new OrderBy(new ClassAttribute(LWCTypeDefinition.class, LWCTypeDefinition.MODIFY_TIMESTAMP), false), new int[]{0});
QueryResult qrTypeDef = PersistenceHelper.manager.find((StatementSpec) queryspec);
if (qrTypeDef.hasMoreElements())
while (qrTypeDef.hasMoreElements())
Persistable persistables[] = (Persistable[]) qrTypeDef.nextElement();
if (persistables.length > 0)
LWCTypeDefinition lwcObj = (LWCTypeDefinition) persistables[0];
ArrayList typeList = LWCCommands.getTypeAttributes("OR:" + lwcObj.toString());
for (Object typeAtribs : typeList)
if (typeAtribs instanceof AttributeDefinitionReadView)
System.out.println(((AttributeDefinitionReadView)typeAtribs).getName());
} else
System.out.println("nothing");
} catch (Exception e)
// TODO: handle exception
e.printStackTrace();
PetrH
Thanks this helps alot and this works to me for windchill 11.0 +
How do i replace
 for windchill 10.2 because this package "import com.ptc.core.lwc.client.commands.LWCCommands;" does not exist in windchill.
Hi @KU_9877195
The trouble is that the command really does not exist in the Windchill 10.2.
I do not know if there is another method to do so. I used version 10,2 many many years ago...
You would need to write own function to do same action as is in higher versions
PetrH
Its hard to make function in 10.2 for me because i dont have that much exposure to 10.2 API.
anyways Thanks for guidance.
Hello @RS_10128209
Go to the Type and Attribute Management and check all subtypes what you want.
There you can see all internal names.
PetrH
Thanks @HelesicPetr
but I want solution programatically /using API
There is a page to see them:
Windchill/app/#ptc1/carambola/tools/createtableview/availableAttributes
Add that your you hostname and URL for your server.
