How to increase character size limit for workflow attribute which is added on task.
NG_10595539
8-Gravel
7 REPLIES 7
HelesicPetr
(To:NG_10595539)
Hi @NG_10595539
What attribute type is it? because in my system if I add a String in the task the limit is over 15000 chars
PetrH
hi @HelesicPetr ,
the attribute is of string type only. And how to check the string limit for the same.
HelesicPetr
(To:NG_10595539)
Hi @NG_10595539
what error and where is shown if the limit is reached?
I guess there can be some custom check of the limit because in my case I was able to add more then 7millions chars.
So OOTB it seams it is "unlimited"
PetrH
Hi @HelesicPetr ,
there is no error shown but the string value is not fully visible. Only 50 characters are shown.
HelesicPetr
(To:NG_10595539)
Oh, you are talking about the window size, not the limit of characters in the attribute 😄
Check following article.
CS164625 - How to size workflow variable input fields on Task Forms in Windchill PDMLink
PetrH
Hi @HelesicPetr ,
the article seems for taskform template, but the mentioned task is not a taskform template. And while displaying the string wanted to display it as 250 characters instead of 50 characters.
HelesicPetr
(To:NG_10595539)
Hi @NG_10595539
So you need to change to task form template.
PetrH
