Version: Windchill 12.0
Use Case: How to integrate CAS unified authentication in windchill12.0? What configurations need to be modified?
Description:
The people in this community would not know what you are trying to do. I suggest that you
Here is the help page for it (not so helpful, right?):
But as I understand it, this is only needed when you are using Thingworx (corrections please!). So if you are using Thingworx you might be better off looking at the Thingworx forum.
https://community.ptc.com/t5/ThingWorx-Navigate/bd-p/thingworxnavigate
This way doesn't work,I'm stuck now, verifying this step. I don't know how to configure the callback address. I've already got the token.
Hi @林唐_10981168
Thanks for using PTC Community,
I wanted to let you know that there are some questions to you on your topic.
If you are in a position to respond to this question, that would be great.
Vivek N
Community Moderation Team.
I've solved it, thank you
