Hi Windchill Gurus,
Our company has an old Windchill 9.1 running on Windows 2003 server, and we are planning to retire windows 2003 server soon, so we want to move it to Linux (RHL-2.6.32)
But I don't find any documents about rehost windchill from Windows to Linux. BTW, all Oracle DBs are running on Solaris which will remain untouched.
I was hoping anyone from the community can give us some advice please.
Jerry
For this you have to follow an installation method of rehosting or else you will have find out all the folder structure references from Windows to Unix. On a high level these are the steps.
cd Windchill/bin/adminTools/rehosting
ant “-Dtarget-ldap=ldap:// cn=manager:passwd@newservername.example.com/” –Dtarget-domain=newservername.example.com
6. Update the db.properties to switch from dummy database to new database. wt.pom.dbHost, instance name, username, password and all.
7. Then update the database reference to new hostname
Update Repository set lastKnownDomain='newservername.example.com' where local=1;
8. Given that all the above steps are done, you should be able to bring the server up. Now you can update the File vault settings from Vault server administrator.
Hi Binesh, We have not yet scheduled to do this yet, will ask for your kind help once we are there. Thanks again!
Do you have any reasons why you are moving from Windows to Linux? Any performance related issues?
We are new to Windchill, contemplating between Windows and Linix Servers, any feedback is appreciated.
What are you and/or your IT department more familiar with, Windows or Linux?
As long as the hardware is the same, I doubt you will see much performance difference between the OSs.
