How to retrive multivalued attribute value in java program
giridhar82
HI
multivalued attribute value in using API?
Regards
Giridhar
Giri,
Here is the two sets of main scripts. You need to build other logics based on your needs. I assume you are in 10 or above and looking API to get IBA values.
//load obj and get IBA Values of IBA
LWCNormalizedObject normalizedObject = new LWCNormalizedObject(wtPart, null, SessionHelper.getLocale(), null);
normalizedObject.load(ibaName);
Object ibaValue = normalizedObject.get(ibaName);
* This can be used to get only String type IBA value
public static String getIBAValues(Object ibaValue){
String ibaValues = ";
if(ibaValue instanceof Object[]) {
Object[] ibaValueArray = (Object[]) ibaValue;
for (Object aIbaValue : ibaValueArray) {
if ((ibaValues.length()) > 0) {
ibaValues = ibaValues + ",";
ibaValues = ibaValues + (String) aIbaValue;
else{
ibaValues = (String)ibaValue;
return ibaValues;
Shown code only to retrieve string type. You can adjust code to take care other data types.
Ayyappan
Thanks Ayyappan.
It worked perfectly fine.
On Wed, Apr 30, 2014 at 6:05 PM, Rajagopal, Ayyappan <
-> wrote:
> Giri,
> values.
> ** This can be used to get only String type IBA value*
> *public static String getIBAValues(Object ibaValue){*
> * String ibaValues = ";*
> * if(ibaValue instanceof Object[]) {*
> * Object[] ibaValueArray = (Object[]) ibaValue;*
> * for (Object aIbaValue : ibaValueArray) {*
> * if ((ibaValues.length()) > 0) {*
> * ibaValues = ibaValues + ",";*
> * ibaValues = ibaValues + (String)
> aIbaValue;*
> * else{*
> * ibaValues = (String)ibaValue;*
> * return ibaValues;*
> other data types.
> Thanks
> Ayyappan
> *From:* Giri G [
