How to save changes to the  file web.xml
VladiSlav
Hello, please tell me how to save changes to the file web.xml (Windchill_home/codebase/WEB_INF/web.xml)?
1 ACCEPTED SOLUTION
Not sure in which context the question is, but generally the file can be modified in any text editor.
If the question is about how to save file from code > The are file handling packages available with programming languages which can be used for that purpose.
May be a more elaborated use-case description will help better understand the ask.
Arpit-Singhthere are examples of working with the web.xml or information, how does it work in Windchill? I only know in General terms how to work with the web.xml, but this knowledge is not enough for me to understand the full picture
Arpit-Singhthank you very much for the useful and accessible information
