How to search modified objects by user?
tthangadurai
7-Bedrock
Hi All,
I need to find the objects modified by a user to solve some issue in windchill. So how to search the modified objects by a specific user?
Keir is correct, you can use the Modified By field under Advanced Search. For example, this finds all parts modified by the user "Site Administrator":
Note that the example above only returns parts that were last modified by the administrator. If you need to include non-latest iterations that the user modified, you'll need to set the Iteration criteria to "All":
For more info on using advanced search, see the Windchill Help Center: http://support.ptc.com/cs/help/windchill_hc/wc102_hc/LclSrchAdvancedSearchPerform.html
5 REPLIES 5
Using advanced search you should be able to add Modified By as a criteria
Thanks Keir.
Thanks Caitlin & Keir.
I am trying the options.
I have added the criteria & context, but what should be the keyword. Please help.
you can leave keyword blank
