How to set WTPartNumber by OIR when part is created from a CAD-item
bschmidt-2
Hi everybody,
I´m using windchill 9.1 and Creo Parametrics 2.
When creating a new CAD-item (assembly or item) in creo I can enter
- name (EpmDocumentMaster.CADName/EpmDocumentMaster.Name)
- description (EpmDocument.NoteIterationInfo)
When cheking in, the auto-creation of a WTPart is enabled. So we get a WTPart with the
- same name (WTPartMaster.Name)
- same description (WTPart.NoteIterationInfo)
as entered.
The WTPartMaster.WTPartNumber is genereated by a counter-sequence. But I want it so be the same as the name (as entered). So I tried to change the OIR of WTPart, but when applying it, the machine can´t find the attribute "name"?! I´m not sure, if I completely understand the OIR. The rule applies to both tables WTPart and WTPartMaster?
Here is the OIR for WTPart and "number" (the older entries are wrapped with a comment):
<!-- set the number to a generated number -->
<!--OLD-ENTRY <AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator"> -->
<AttrValue id="number">
<!-- add a V prefix for variant parts -->
<Value algorithm="wt.rule.algorithm.BooleanBranch">
<Value algorithm="wt.rule.algorithm.EqualsTest">
<Attr id="genericType"/>
<Arg>variant</Arg>
</Value>
<Arg>V</Arg>
<Arg></Arg>
</Value>
<!-- the sequence -->
<!-- OLD-ENTRY<Arg>{GEN:wt.enterprise.SequenceGenerator:WTPARTID_seq:10:0}</Arg>-->
<Attr id="name"/>
</AttrValue>
Any suggestions?
greetings Benjamin
0 REPLIES 0
