CAD File Publishing
  • December 9, 2014
  • 2927 views
Hi all,
I Installed and registered the cad software (Autodesk2014) in workgroup manager. I upload a file but I have some problem publishing it.
This is when I click on the visualization.
Why my creo view is disabled?
Thanks!
PTC CS156542
  • If .DWG files are checked in using WGM for AutoCAd, no worker is required to publish them
  • Creo View can open such DWG files natively
PTC CS36856
To automatically generate representation for the pre-converted files (such as DWG)
1. Add following properties to wvs.properties (for Windchill 10.2):
  • Use the xconfmanager command in a Windchill Shell, for example:
xconfmanager -t "codebase/WEB-INF/conf/wvs.properties" -s "worker..DWG=DUMMY,preconverted=true" -p
2. Clear the Tomcat and Info*engine cache.
- Tomcat cache at <Windchill_Home>\tomcat\instances
- Info*engine cache at <Windchill_Home>\tasks\codebase\com\infoengine\compiledTasks
3. Restart Windchill MethodServer .
Luar1-VisitorAuthor
Hi Vitaliy,
Yes, But thats my problem now, Publish is not working after I checked in using WGM. As u can see on my screen shot. I dont know what is wrong.
1. xconfmanager -t "codebase/WEB-INF/conf/wvs.properties" -s "publish.service.verbose=true" -p
2. restart Windchill Method
3. Rebublish same Acad file
4. Show %WT_HOME%/logs/Method*.log
