Hi.
I cann't use PromotionNotice and StandardMaturityService.promoteTargets() method.
How can i change state of WTDocument by java code?
Thanks.
Hi, Vasiliy
wt.lifecycle.LifeCycleServerHelper.service.setState((wt.lifecycle.LifeCycleManaged )Object, wt.lifecycle.State.toState( "UNDERREVIEW"));
Hi, Vasiliy
Another way LifeCycleHelper.service.setLifeCycleState(object,State.toState("CANCELLED"));
Hi kaushik,
Is there any way to read the life cycle of any object from OIR.
Example:
On part creation,how the lifecycle value populated from OIR..
Example:
Hi Chan,
In OIR you will find below lines.
<!-- set the lifecycle -->
<AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
<Arg>
<!-- Translation of the word "Basic" must be the same as the translation done in commonLifeCycles.xml -->
<?loc-begin key="BASIC_LIFECYCLE_NAME" maxlen="30" match="commonLifeCycles.xml:BASIC_LIFECYCLE_NAME"?>Basic<?loc-end?>
</Arg>
</AttrValue>
If you change the name from Basic to some other name (For example Approval) then that particualr object will follow Approval.
Thanks ,
Kaushik
Hi Kaushik,
Thanks for the reply.But in my case,i am trying to know the customization part(How the OIR values are been displayed in creation page).Which APi has been used to retrieve values from OIR.
Example: In part creation page,how values are been retrived from OIR.
