hello! everyone:
When I check in file's it happens "cannot check in place holder document", I want to know what's the problem and how to solve it. it's urgency for me!
Thanks!
To close this community thread on Windchill "cannot check in place holder document" error
Summary of the exchanges and list of references:
Following is the excerpt from 'Using Pro/E with Windchill' Guide (http://www.ptc.com/WCMS/files/83442/en/UsingProeWithWCGuide.pdf)
I hope it helps.
Using the Add Placeholder Command |
The Add Placeholder command allows you to attach a CAD Note: The incomplete object must first be uploaded in order that: |
Tondy
