How to sort parts in structure
VasiliyRepecki
Hi.
Is there any way to set sorting (comparison) rule for parts in part structure pane?
I have some menu right above part structure pane, but there is only one column "Identity" for sorting with no possibility to add other columns.
Can i define my own patr's comparator to be used in part structure?
Thanks.
KD
(To:VasiliyRepecki)
Hi Vasiliy,
Not sure whether you can define your own part's comnparator to sort in part structure but you can add other column like name or number there apart from the "identity" column.
All the below screenshots are from 10.1 M040
Go to Views --> Manage Structure Views
click on edit --> Set Column Display. Move the necessary columns from Left and side to Right hand side and click on Finish.
Kaushik
You don't see the other attributes than the identity(Number attribute) on the structure pane, I guess that's the reason why Windchill doesn't shows the filtering options there.
KD
(To:VasiliyRepecki)
Hi Vasiliy,
Kaushik
