Content upload failed because of invalid response from the server
  • March 12, 2014
  • 8040 views
Dear All
When i try to save and upload or Check in a large assembly. My event manager show failed and invalid response from server.
I have attached screen shots. Please give your valuable comments.
Regards
Viswanathan.K
hello
I am facing the same problem on Windchill, did you find a solution to your.
Thank you for your help
The "upload failed because of invalid response from the server" message is fairly generic and can have a number of causes. If the upload failed due to a server side issue, then there should be a corresponding error in the Method Server log that gives a better description of the cause.
Are you seeing this issue with all uploads? Or, does it only occur for certain objects, or for certain users/machines?
