The error in Conflict management reads as follows
Attribute values cannot be added ,removed or changed
Hi Joseph,
Refer the below support article. There is an SPR raised against this issue.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS226716
Is there a workaround??? The article hasn't been updated in over 9 months.
I just pinged tech support. There is no workaround and the SPR is tentatively planned to be addressed in Windchill 11.0 M030.
