Hi i'm Windchill engineer
I had just started and i need your comment about windchill reverse proxy
windchill was built in one network
If someone goes on a business trip to another location or wants to access Windchill from another vendor, he or she access it as a reverse proxy.
For this, I refer to CS68466How to setup a reverse proxy for Windchill PDMLink.
Even if you have completed the above procedure, access from a PC with a different network is not allowed
I want a document that looks a bit more detailed or actually complete.
I would be grateful if anyone could answer.
Please Help me please
Thank you.
Hi
I think you may look into these approaches to access Windchill over internet :
You may need to work with your system admin or network admin to configure this configurations.
Hi arshad
I opened port 80 [used in Windchill] through port forwarding.
And all of the firewalls are off.
Accessing this way will show up to the login page, but not after login.
However, I did not access it in the reverse proxy configuration, and I accessed Windchill simply through the external Ip.
Is it to configure a reverse proxy because this approach is not possible?
Is there a way to configure a reverse proxy?
I looked at CS68466 but did not understand it properly.
Can I configure Windchill Directory Server and change configuration information on another PC in the same network to configure a reverse proxy?
Thank you.
