I want checkin a assembly 3d model to a new baseline
Sulibo
Hello, I created baseline for an assembly model in Windchill;
Later, I opened this baseline version assembly model in Creo.
And I add some 3D parts to this baseline version assembly.
My question is: how can I save this modified 3D assembly to a new baseline?
Does any one know how to do this,
Or some alternate solution
There are basically two ways to do a custom checkin, 1st is from creo with the part open. File, Check-in (arrow to the right) > custom check in.
Second, if you rmb or checkmark in the workspace the object and do check in. On the set options wizard page, select create baseline.
A note of Creo (dis)functionality. If the ootb "Baseline" is turned off, aka instantiable "no" this will still create a baseline and ignore all of your OIR's if you have custom Baseline OIR's. PTC "Works to product specification"
In simple, you would do a custom check-in of the upper level assembly, check marking the create baseline.  Additionally, you can create a new baseline in Windchill, and use the configuration rules in the collector to grab the appropriate components.
Sulibo
(To:jbailey)
Hello, @jbailey
Thank you,
About custom check-in : our IT support dont know how to do,
Would know this custom check-in meaning :modify the configuration or need develop the check-in function.
Sulibo
(To:jbailey)
Hello ,@jbailey ,Thanks very very very much,
you slove my problem .
