I have a custom utility on Promotion Notice and I want to retrieve all task data like name, number, role, assignee, activity name, vote, and comments as well. So, I retrieved below data but i am I am STRUGGLING to get user comments and assignee name while performing the "approve" task. of Poomotion Notice
I need a java API so that I can use it in my utility where I am getting other details .
I know that i ill get required info from this class WfVotingEventAudit but How can i get this from Promotion Notice
I used below code in wf but getting class cast exception :
wt.fc.collections.WTArrayList auditCol = (wt.fc.collections.WTArrayList) wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess) ((wt.workflow.work.WfAssignedActivity) self.getObject()).getParentProcess(), null, null, null); System.out.println("***Transition Expression: Audit = " + auditCol.toString());
I did this slightly differently since I was using eSignature. This object has everything but you must enable the task to have signature required which forces users to have to enter password to complete. In my workflow, I use this code to copy the comments to a discussion forum associated with the promotion request or change object.
QueryResult result = PersistenceHelper.manager.navigate(promotion, SignatureLink.SIGNATURE_ROLE,SignatureLink.class,false);
LOGGER.debug("Read in: " + result.size() + " Signatures");
SignatureLink link = null;
//Loop through the signatures
while(result.hasMoreElements()) {
link = (SignatureLink) result.nextElement();
LOGGER.debug("Found " + link.getComments() + " comments");
//Get user from signature
QueryResult userLink = PersistenceHelper.manager.navigate(link.getSignature(),UserElectronicIDLink.USER_ROLE,UserElectronicIDLink.class);
WTUser user = (WTUser)userLink.nextElement();
LOGGER.debug("Got user: " + user.getFullName());
//Get Comments
String comments = link.getComments();
if ((comments == null)||(comments.trim().isEmpty()))
LOGGER.debug("Caught case of no comments");
comments = "No comments entered.";
//Get Vote
String vote = link.getVote();
LOGGER.debug("Got vote: " + link.getVote());
//Get Role
LOGGER.debug("Got role: " + link.getRole());
String role = link.getRole();
Hello @@_1647,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
