May 22, 2024 9:51 AM UTC
I want to retrieve all task data like name, number, role, assignee, activity name, vote
@avillanueva
I have a custom utility on Promotion Notice and I want to retrieve all task data like name, number, role, assignee, activity name, vote, and comments as well. So, I  retrieved below data but i am I am STRUGGLING to get user comments and assignee name   while performing the "approve" task. of Poomotion Notice
I need a java API so that I can use it in my utility where I am getting other details .
I  know that i ill get required info from this class WfVotingEventAudit  but How can i get this from Promotion Notice
I used below  code in wf but getting class cast exception  :
wt.fc.collections.WTArrayList auditCol = (wt.fc.collections.WTArrayList) wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess) ((wt.workflow.work.WfAssignedActivity) self.getObject()).getParentProcess(), null, null, null); System.out.println("***Transition Expression: Audit = " + auditCol.toString());
avillanueva
May 22, 2024 11:22 AM UTC
I did this slightly differently since I was using eSignature. This object has everything but you must enable the task to have signature required which forces users to have to enter password to complete. In my workflow, I use this code to copy the comments to a discussion forum associated with the promotion request or change object.
 QueryResult result = PersistenceHelper.manager.navigate(promotion, SignatureLink.SIGNATURE_ROLE,SignatureLink.class,false);
			LOGGER.debug("Read in: " + result.size() + " Signatures");
			SignatureLink link = null;
			//Loop through the signatures
			while(result.hasMoreElements()) {
				link = (SignatureLink) result.nextElement();
				LOGGER.debug("Found " + link.getComments() + " comments");
				//Get user from signature
				QueryResult userLink = PersistenceHelper.manager.navigate(link.getSignature(),UserElectronicIDLink.USER_ROLE,UserElectronicIDLink.class);
 WTUser user = (WTUser)userLink.nextElement();
 LOGGER.debug("Got user: " + user.getFullName());
 //Get Comments
				String comments = link.getComments();
				if ((comments == null)||(comments.trim().isEmpty()))
		 LOGGER.debug("Caught case of no comments");
		 comments = "No comments entered.";
				//Get Vote
				String vote = link.getVote();
				LOGGER.debug("Got vote: " + link.getVote());
				//Get Role
				LOGGER.debug("Got role: " + link.getRole());
				String role = link.getRole();
Emeritus
May 27, 2024 2:50 PM UTC
Hello @@_1647,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
