In Windchill 12.1, is it possible to export WhereUsed Report only to a level expanded in the table?
Srivalli
8-Gravel
There is a part being used in multiple sub-assemblies. The table was showing around 150 parts when expanded to a certain level (3). When we try to export the report, it says an error that rowLimit property is set to 20000. Is it possible to export only those 150 parts to CSV or XLS.
Export of all rows is working for XML, but it's not the desired format. Can someone help?
HelesicPetr
22-Sapphire I
(To:Srivalli)
Hi @Srivalli
Answer to your original question>
Unfortunately it is not possible to do so in the Where used table OOTB.
If you always want to report the 3 levels, you can create own Report template where you build 3 level structure to report only that 3 levels where the parts are used.
here is an example with a one level. You can add more levels to the report
CS210416 - How to create a Where Used report for WTParts in Query Builder
PetrH.
8 REPLIES 8
TDT
(To:Srivalli)
Hi @Srivalli,
Are you using any custom report?
Srivalli
8-Gravel
(To:TDT)
@TDT  we are using the OOTB option 'Export'.
HelesicPetr
22-Sapphire I
(To:Srivalli)
Hi @Srivalli
Try a xlsx format.
PetrH
Hi Petr,
It's the same error with this format too.
HelesicPetr
22-Sapphire I
(To:Srivalli)
Hi @Srivalli
I would try to increase the limit
https://www.ptc.com/en/support/article/CS350579
PetrH
TDT
(To:Srivalli)
Hi @Srivalli,
Do you want to have only single level report?
Srivalli
8-Gravel
(To:TDT)
@TDT 3 levels
HelesicPetr
22-Sapphire I
(To:Srivalli)
Hi @Srivalli
PetrH.
