Does anyone have a file that they have used as input for the CSV2XML tool? I've been unable to find anything and have tried inputing generic files to see if I can figure out how they are processed etc, but they just generate near empty xml files.
Hi Dan,
I used this once in Intralink 9.0 for loading IBA and it worked for me. Here's a file with some notes I did that time. I hope it helps.
Boris Blajevici
Thanks, I'll let you know how it works out and when I get a template for file loading I'll post it.
Dan
Did you check the %WT_HOME%\loadFiles folder for sample csv and resulting xml files? Also see the %WT_HOME%\loadFiles\csvmapfile.txt file for definitions.
Windchill® Data Loading Reference and Best Practices Guide has some information on working with CSV2XML utility.
