Install Pro/Intralink 9.1 w/bundled Oracle in Multi Server environment
bmills
Windchill GURUs,
Is there a way to perform an Advanced installation of Windchill/Intralink 9.1 using the bundled Oracle option and separate the Oracle database to it's own server. I havea secondary server available that could run the Oracle databse and would like to try a tests installation. The advanced installation w/the Intralink option does not appear to have this capability.
Hi Bob, why the need to use the OSA anyways? In my mind it can cripple you in this kind of situation where as a plain only oracle install is very simple. Let me know if you have some basic install questions and I can assist.
As for your original question, I'm not 100% sure you can do a split server install (application and database server) using the OSA.
Steve Vinyard
Application Engineer
[cid:image001.gif@01CB121C.4066E320]
