Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Good day fellow Pro/Intralink users. We are currently running Intralink 3.4. We had a user get an error that said the disk space was full. I then realized that the hard drive was indeed full. I cleaned up the hard drive and moved non Intralink info to another drive. Then we received the PDMc_CheckIn::MakeFileTransfer() 403. I looked it up on the PTC website which told me that the database was set to read only. I logged into the DSMU and changed it to read/write. I now have 2 users that can check files in out of 14 users. The weird part is that the 2 users have identical Dell laptops while everyone else has desktops. Has anyone encountered this problem before? Any information would be greatly appreciated. Nathan Zimmerman Product Development Coordinator PTC Systems Administrator Engineering 1000 Buffalo Road Lewisburg, PA 17837 USA
I figured it out just as I sent the email out. I set the database as read/write, but the vault was still set to read only. I don't know why the people with the laptops were still able to check things in. Nathan Zimmerman Product Development Coordinator PTC Systems Administrator Engineering 1000 Buffalo Road Lewisburg, PA 17837 USA
