Intralink 3.4 on Win7 with new domain - FIXED
PeterBrown
7-Bedrock
Hola -
We've been running 3.4 M062 on Windows 7 for a while. Edited the .bat file for the "Dsun.java2d.noddraw=true" stuff and all has been well.
There is now a new problem.
We've switched domains, so that the user is now a domain and not a local user. When I start intralink, I get the splash screen and then it dies. The .proi.log file shows "java.lang.NullPointerException null". This may or may not be the problem.
So, with the same workstation and batch files, if I logon as a local user and run proilink3.4.bat, Intralink starts and runs normally. If I logon as a domain user, Intralink's splash screen appears and then dies and it Intralink does not start.
The Intralink server is now on a different domain as the workstation, but I can successfully ping both ways either by hostname or ip address. I've also tried changing tnsnames.ora from the server's hostname to its IP address with no success.
Running out of ideas here....
TIA
Thanks to Joel and Doug - but it's still not working.
Tried setting the compatibility mode for javaws.exe to Vista SP2 - still didn't work
Renamed slqnet.ora -still didn't work.....
We have not been using Pro/I for a couple of years now, but I recall a similar sort of issue when our servers moved from one domain to a different one in a data center. (Server and users were originally part of the same domain.)
Try messing with this line in the SQLNET.ORA file on your server:
SQLNET.AUTHENTICATION_SERVICES= (NONE)
SQLNET.AUTHENTICATION_SERVICES= (NTS)
I don't remember which of these is the DEFAULT value in the file, but whatever one it is, change it to the other and see if that helps. Sometimes when there is a difference between the server and the Domain clients, Pro/I can wig out like this for reasons I still don't understand.
Good luck.
--Jim Augeri
MCAD Tool Support, Eng Tools (NM75)
Honeywell Aerospace
9201 San Mateo Blvd. (MS B-3)
Albuquerque, NM 87113
Phone - 505.828.5808
Fax - 505.828.5500
"Never again will one generation of veterans abandon another."
Founding Principle of Vietnam Veterans of America
This e-mail message and any attachments are for the use of the intended recipient(s) and may be controlled by U.S. export control laws. Any unauthorized review, use, disclosure or distribution of this communication in whole or in part without the express written consent of Honeywell, or the U.S. Government as required, is prohibited. If you are not the intended recipient(s), please contact the sender by reply e-mail and destroy the original message and any copies of the message as well as any attachment(s) to the original message.
I'm completely baffled. I can only get Pro/I to start if I am logged in as the original user who installed Win7/ProI/ProE AND it is in the original loadpoint! The software was installed before the workstation joined the new domain.
ALL EXAMPLES ARE LOCAL USERS
Original user: Engineering
Original loadpoint: e:\ptc\proiclient
THIS CONFIGURATION WORKS
User: Engineering
Loadpoint: E:\ptc\proiclienttest
THIS DOES NOT WORK
User: Test
Loadpoint: e:\ptc\proiclient
THIS DOES NOT WORK
User: Test
Loadpoint: e:\ptc\proiclienttest
The loadpoints are just copies of the original, not reinstalls.
I'd like to thank everyone who responded - Doug, Tim, Jim, and Joel.
Ultimately, reinstalling and tweaking permissions did not correct the issue.
What DID work was to replace the JRE bundled with Pro/INTRALINK 3.4 with an Oracle-provided one.
1) I renamed <loadpoint>\i486_nt\jre\bin and <loadpoint>\i486_nt\jre\lib to <loadpoint>\i486_nt\jre\bin_old and <loadpoint>\i486_nt\jre\lib_old
2) I browsed to the c:\program files(x86)\java folder and copied the \bin and \lib folders to <loadpoint>\i486_nt\jre\
All is well.
Thanks again.
PS: Upon later use I discovered that JRE 7 would not allow Pro/LOCATE to work. I went back through versions until I found 1.5.1 did the job.
