Intralink 3.4 to 9 point what?
angelina-sherid
When migrating to Windchill/Intralink 9.1 to I need to first install 9.0 and then upgrade to 9.1 or can I go directly to 9.1?
Thanks in advance,
Angie
Angie,
I believe there is a document on the PTC website that tells you the upgrade path. I would download that upgrade path documentation and see what it says.
HTH,
Regards
Alexius C. Chukwuka
IT Analyst, PDP Systems
John Deere Power Systems
Product Engineering Center
*Voice: 319-292-8575
*Mobile: 319-429-5336
*Fax:319-292-6282
*E-Mail: -
CONFIDENTIALITY. This electronic mail and any files transmitted with it may contain information proprietary to Deere & Company, or one of its subsidiaries or affiliates, and are intended solely for the use of the individual or entity to whom they are addressed, shall be maintained in confidence and not disclosed to third parties without the written consent of the sender. If you are not the intended recipient or the person responsible for delivering the electronic mail to the intended recipient, be advised that you have received this electronic mail in error and that any use, dissemination, forwarding, printing, or copying of this electronic mail is strictly prohibited. If you have received this electronic mail in error, please immediately notify the sender by return mail.
The Intralink Data Migrator Compatibility Matrix documents the upgrade path from Intralink 3.4. You can download it from
Designation: Non-SSA/Finmeccanica
Angelina,
We performed an Intralink 3.4 to Intralink 9.1 M050 migration last year and we were able to go directly to 9.1 M050. The install media will allow you to install a clean install of 9.1 M050 without having to install a lower rev first. The only thing to keep in mind is that if you will be using a remote file server the remote server administration tool will install the base 9.1 and needs to be upgraded to the proper maintenance release.
Bob Mills
Engineering Software Administrator
DRS Training and Control Systems, LLC
645 Anchors Street
Fort Walton Beach, Florida 32548
850-302-3241
rmills@drs-ds.comwww.drs-ds.com
