Sachin,
The Promote and Revise transitions are independent of each other. The
Promotion process does not perform a revise operation only a set state
operation as a part of its workflow. The Revise transition describes what
should happen when a user performs a manual 'New Revision' action.
To accomplish your scenario, the user would navigate to the RELEASED CAD
Document and create a new revision (i.e. Version 2.1) . Your transition
should then specify that a revision from RELEASED should go to the
Development state. The user works on the CAD doc(s) until they are ready to
promote it. Then they create a Promotion Request and select RELEASED as the
target state.
H. Lewis Kennebrew, II
Vice-President, Operations
ProductSpace Solutions, Inc.
"Your Products to the Nth Power"
2021 Midwest Road, Suite 200
Oak Brook, IL 60523
Work: 630-495-2999x8101
Fax: 1-877-562-5144
> Revise" through promotion request.
> e.g.
> Part is available as "abc.prt" under "Released" state with Version 1.0 &
> user want to promote using promotion request in Intralink 8 to "Development"
> & Version "2.0"
> Using above life cycle user could able to promote from released to
> development but ...
