Is SQL Server included in PSI?
CHASEONHO
18-Opal
Hi i'm seonho
We are re-reading the Windchill Installation Guide.
Or should I install it separately?
thanks
TomU
(To:CHASEONHO)
Yes, either Oracle or SQL Server needs to be installed and configured prior to installing Windchill.
You probably should read through the installation guide and other related documents.
https://support.ptc.com/WCMS/files/168349/en/WCInstallConfigGuide.pdf
It is not included in the PSI.
should i installed SQL Server?
before i installed windchill,I have not installed SQL Server separately.
TomU
(To:CHASEONHO)
