Hi i'm seonho
We are re-reading the Windchill Installation Guide.
Is SQL Server included in PSI?
Or should I install it separately?
thanks
Yes, either Oracle or SQL Server needs to be installed and configured prior to installing Windchill.
You probably should read through the installation guide and other related documents.
https://support.ptc.com/WCMS/files/168349/en/WCInstallConfigGuide.pdf
It is not included in the PSI.
should i installed SQL Server?
before i installed windchill,I have not installed SQL Server separately.
