Is it possible to export Part Rename History over UI or WRS?
YannickM
Version: Windchill 12.1
Use Case: Is it possible to export Part Rename History over UI or WRS or Query Builder for automatic processing?
Description:
I need to export the rename history of several parts from Windchill. For export, I usually create a view and then save it as an Excel file. Is it possible to include the rename history in a view? Alternatively, is it possible to retrieve the rename history for a part via WRS? Unfortunately, I haven't found a solution using either method. I haven't been able to achieve this using the Query Builder either. I hope someone has a tip for me.
Using query builder you can extract Part Rename History
How to create a report that lists parts renamed
Marco
Marco
