We creates our organization via loadfile and we'd like to set "Allow sourcing administrators to create organizations" attribute as "yes" (see screen below). Is there a possibility to do this via loadfile? Or is there an another way to do this without using UI?
Thank you for a help,
Damian
Per the csvmapfile.txt:
OrgContainer~create~wt.inf.container.LoadContainer.createOrgContainer~containerName~containerTemplateRef~businessNamespace~sharingEnabled~creator~owner~subscriber~conferencingURL~description~internetDomain~OrganizationAddress~conferencingID~restrictedDirectorySearchScope
It doesn't look like any of those available attributes are for setting that option. This would be an enhancement.
