Version: Windchill 13.0
Use Case: I'm trying to use pdmlink's family mpmlink. It is said that department data is used to store information about attributes related to the various functions of the plant, but in creating downstream, only the plant is created and no department is created.
Description:
screen shot
Hi @JM_10888789
Help - Creating Department Data from Windchill
PS> try to checkout - control a assigned license to a user and also check ACL.
PetrH
Hi @JM_10888789
Iam sure you have to assign the departments to the plant where you want to use it.
PetrH
How do i assign departments to a plant?
The button is disabled.
Hi @JM_10888789
PetrH
Is there a license required to use this content?
Even if you create a department, there are no departments created in the tab. I've added Design, Manufacturing, to the List of Plant-Specific Views.
This is an administrator account. PTC Manufacturing License is included.
