I've actually checked out a couple of the ootb tables, and there isn't anything in there which 'shows' the view dropdown. Actually, the only thing in the product/list.jsp that seems to even relate to the anything other than help or page limits is showCustomViewLink, but I had already had that param set in my renderTable.
<jca:rendertable showcustomviewlink="false" helpcontext="ProductsHelp" model="${tableModel}" showcount="true" showpaginglinks="true" pagelimit="${noOfRows}"/">
Just to make sure I wasn't missing anything, I did add everything to my renderTable tag, but the current view is still not showing up.
You have the ability to specify or override the default view id. I would try
that and set it to one already existing and used in other OOTB tables. It
sounds like the table you are using is submitting its id as one without a
registered view id in the TableViewDescriptor database table. You can create
your own view, but you have to use Windchill API and register it and clear
out the TableViewDescriptor and ActiveViewLink tables and restart servers.
An example of this is in the Customizer's guide, but it's a basic version
not giving you all the details.
You need to include codebase/WEB-INF/lib/wncWeb.jar in addition to just codebase. I of couse a bunch of other stuff but this jar is essential for UI customization code compilation.
Eclipse should find it then.
Sent from my Verizon Wireless BlackBerry
