Java retrieve Manufacturer Sourcing Status (amlPreferenceData)
jliu-2
After I get ManufacturerPart, I would like to get its Manufacturer Sourcing Status (amlPreferenceData). Which field should I use? e.g. Part Number = mfgPart.getNumber(). Manufacturer Sourcing Status = mfgPart.getAMLPreferenceData()? I can not find it. Please help!
lmouchard
(To:jliu-2)
the sourcing status is set on the Sourcing Relationship (AXLEntry) between the Manufacturer Part and the OemPart, this status depends "where" the manufacturer part is used
I would say the way to go would be:
  1. start from your OEM Part
  2. use the service AXLService.getAML method, you'll get a collection of those relationships
  3. filter your relationships to get the one that matches the manufacturer part
Loïc
