Load info for many Problem Reports
MikeLockwood
22-Sapphire I
We routinely load Documents and WTParts, but currently have a different challenging situation.
We are using a sub type of Problem Report to take the place of a paper form and process (unrelated to Problem Reports - this is just a convenient object type to use in Windchill).
There are about 300+ of these paper forms, duly routed and approved, and with data that matches attributes for the new sub type. All the info from these paper forms is in a spreadsheet.
Question: Is there any way to "bulk load" a few hundred Problem Reports into the system?
You can also download the windchill loader documentation from ptc.com for more details.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis - TCM
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
A bulk loader for PR's is actually probably one of the easiest loaders to create. You just literally create a new ChangeIssue object, set all the needed info (name, priority, category, etc), and then the changehelper has a 'save' for PR's:
pr = (WTChangeIssue)ChangeHelper2.service.saveChangeIssue(pr);
If you want more detailed info just let me know.
Chris
