Material parameter - I want below parameters to be added in Windchill BOM.
jvadalia-2
I have the similar case.
I have a Material file (MS_Plate_5THK) created, under which i have created user defined parameter RAW_MATERIAL whose value in string is "5mm MS Plate"
PTC_MATERIAL_NAME
RAW_MATERIAL (This is coming from material name and not from Part file)
I know i have to play with attributes in Windchill.
What steps should i do in Windchill attributes?
Jignesh
HelesicPetr
(To:jvadalia-2)
Hi @jvadalia-2
Create global attribute named as the designated attribute
and then define this attribute on the CAD Document soft type as a global attribute
All steps in Windchilll should be done in a Type and attribute management .
PetrH
Hi @HelesicPetr
Thanks for your reply.
I will have a try and update.
Jignesh.
