Message Popup on Custom JSP in Workflow
BrianToussaint
Version: Windchill 12.1
Use Case: We have custom jsp pages for workflows and would like to have a couple of popups to help guide users in what is expected.
Description:
Let's say we have an attribute called "Validation" and we want to have an information popup to explain how this should be done.  How would I do this in the custom jsp template?  Kind of like on the page to create this there is an "i" next to Message Tags and Labels.
Did you want to do validation or just have something like a mouse over or tooltip text? We did a validation that is triggered off the complete button which we had to override the completeButton.jsp to insert a called to a javascript. That javascript is where its all done:
completeTask.setButton(true);
//completeTask.setEnabled(true);
completeTask.setTitle("Complete Task");
completeTask.setDesc("Complete Task");
completeTask.setEnabled((!myNmWorkItem.isCompleted() && !myNmWorkItem.isSuspended() && myNmWorkItem.isMine()));
//10-24-2024 addition - Parent JSP page must contain this validtion script
completeTask.setOnClick("validate_Complete()");
This calls the validate_Complete() function where in my case, I can checking to see if comments were entered for a variable called comments and that a checkbox was checked:
function validate_Complete()
    var c=document.getElementsByTagName("textarea")
    var comment;
    for (var k=0; k<c.length; k++)
        if (c[k].name.indexOf("comments")!=-1)
            comment=c[k];
            break;
    if (IsEmpty(comment))
        alert("Please enter comments");
        return false;
    c=document.getElementsByTagName("input");
        if (c[k].name.indexOf("Acknowledge")!=-1)
            if (!c[k].checked)
                alert("Please check the 'Acknowledge' checkbox to accept agreement.");
                return false;
            break;
    return true;
You can also do this in Java code with a transition expression but that runs on server side after the button is clicked and you would trip a WTException with a helpful message.
@avillanueva we are looking for tooltips
Hi @BrianToussaint,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
