I have successfully had a test migration from Intralink 3.4 M030 to Windchill Intralink 9.1 M060.
I've also tested replication with a small number of files.
It works, but it would take weeks to re-replicate to my 2 remote sites.
And my management finds ad-hoc replication unacceptable.
When we go live, they want everything already replicated.
The replica files from 3.4 are aready at the remote sites.
Can they be migrated as well?
If not, what other options are there to re-replicate quickly after migration?
Gerry
Thanks to all that replied.
Most people recommended the local replication method, which would work best for us.
In their documentation, PTC recommends this method as well, but does not document the procedure itself.
They state that it should only be done by PTC services.
However, several of you sent me the procedure, which appears to be very simple.
It should be very easy to test using a couple of virtual machines.
Thanks again!
Gerry
