Missing link of cad documents for checkin
Ketan_Lalcheta
Hi
I have an assembly file which is having only one part file as dependent. These both cad are not on windchill.
Unfortunately , I have only assembly file on local disk without having its part file. What I need to do is to checkin assembly into windchill... But it is asking for missing part file. How to check-in assembly with missing link for assembly file.
Any thought would be of great help.
Not possible. The assembly file only has info about the component's being mated within the assembly - it does not include any info about the component.
@Ketan_Lalcheta
Yes, Mike's right.  You have to import the component to check it in.
James
Ketan_Lalcheta
(To:JHall)
Sorry but I am not getting What you are saying.
Does assembly file must have Creo parts used for assembly loaded into Creo ?
If I only load i.e. open assembly without it's child part and try to do check-in , would check-in be successful ?
Doing this from Creo is blocked by windchill.my query is how to do check-in of assembly in this scenario.?
It is blocked from Windchill because you do not have the complete structure to check-in.
You have 2 threads essentially asking the same question. See the other one for additional answers.
Yes. one thread from cad side and one from windchill side..
How then wbm is allowing to check-in data without complete structure.?
