Hi Everyone,
I am working with model-check to add the new parameters, but I can't able to add a run-by model check. I tested in Creo parametric to run the interactive model check there I got parameters.
Thanks in Advance,
Amir
Thanks for the reply and suggestion.
I am looking for an automatic geometry check - reference, missing components, add & rename parameters, parameter value get from Excel, and upload/add-in model kind of way I looked. I found that Modelcheck can do that. I want to know how to do that.
I tested in Creo Parametric few things worked for example adding new parameters, but we can do it manually. One more way I found we can use the modelcheck.bat file to upload the new parameter into the CAD model from the .txt file.
Amir
