You know, when you are wcadmin, and you browse in a WTObject, in the Collaboration/Team tab, you can change the participants of the team of the object. You can add roles and so on.
I want to do the same thing with a normal user.t I cannot. I tried to open a lot of ACL's, It does not work. I do not figure out how it works.
Thank you for helping.
This permission is provided to:
Site, Org admin
Manager of the Product/Library
Can also provide to regular users via Policy Adminstrator, with Modify permission for the Team object type. Note; This permission gives 3 of the 4 actions that the others have hard coded: Add User to Role, Remove User from Role, Remove Role. It does not provide Add Role.
It doesn't work, mike ![]()
I granted the change permission (and all other permissions) for the team type for my user in the product cabinet, it does not change anything. I tried to put the ACL in the org cabinet or the site cabinet, but it does not help.
I did my tests in a fresh test product without any policies or concurrent rules.
Thank you for your help.
Ok it finally works. The tricky solution is to define the ACL ( for the Team object as said upper) in the System domain of the container (and not the Default domain as usual).
