Mount Windchil server procedure?
MS_Santos
Hello ,
Would you have any procedure to mount a Windchil server? a step by step, would it be Windows 2019 machine, PDF, even video for that?
BenLoosli
(To:MS_Santos)
Do you mean install? File vaults? Can you be more specific since mount can mean many things?
If I refer to my own installation, I have the entire application installed on mount for a netapp filer (RHEL). So long as the relative path of the mount is the same, it can be moved to new hosts easily. Is your installation already installed or are you looking to start that process?
Hello, today I have nothing I need to start from scratch.
BenLoosli
(To:MS_Santos)
Read, Read and re-read the PTC Windchill Installation manuals!
Every installation is different with different settings. I have 2 Windchill systems and they act differently for no reason that I can figure out. Both are installed and upgraded with the same basic procedure that I have written over the years and tet=sted with many installs and upgrades.
MS_Santos
(To:BenLoosli)
Hello, I need to start with the basics, where do I find these links? I need to start from the base and then advance
BenLoosli
(To:MS_Santos)
