Multiple Startup Script errors on Winchill WGM 11
MH_10366957
I am receiving these 5 script errors every time I boot up Windchill and I am trying to figure out the root cause of these. They seem to be caused when loading the home page, and once I click "no" on all of them I can use WGM just fine.
Mark
rlampley
(To:MH_10366957)
Change the homepage in your wgmclient.ini file to something other than PTC homepage and these errors should go away.
rlampley
(To:MH_10366957)
That did the trick, is there any reason why the default home page causes these errors?
