Hi All,
Good Day To You..
I'm trying to install Windchill 9.1 M070 and as per that, I need to install SQLServer 2005 Enterprise Edition.
So, I need exact collation of SQLServer 2005 which should match for windchill 9.1 M070.
Kindly request you to guide me.
Thanks in advance .
Windchill requires the collation Dictionary Order, Case-sensitive, for use with 1252 Character Set (SQL_Latin1_General_CP1_CS_AS). You can find the collation requirement as well as additional information about installing Windchill with SQL Server in the Windchill with Microsoft SQL Server Installation and Planning Guide
