Version: Windchill 12.0
Use Case: When selecting Check Out on a wtPart the object is checked out to the user. There are no actions available after check out.
Description:
If they use Check Out and Edit then they have normal actions.
It seems that the current version/view is "working copy" if they select Info in the history table for the "Original version" then menu options are available again.
the ReassignViewsFilter filter is using the existing isInRole method in the ValidationHelper class
looks like there is a class cast exception thrown in our custom ReassignViewsFilter class
Hi @LG_10096154,
Anurag
