No Action options after Check Out of wtPart
LG_10096154
Version: Windchill 12.0
Use Case: When selecting Check Out on a wtPart the object is checked out to the user. There are no actions available after check out.
Description:
If they use Check Out and Edit then they have normal actions.
It seems that the current version/view is "working copy" if they select Info in the history table for the "Original version" then menu options are available again.
LG_10096154
(To:LG_10096154)
the ReassignViewsFilter filter is using the existing isInRole method in the ValidationHelper class
looks like there is a class cast exception thrown in our custom ReassignViewsFilter class
HelesicPetr
(To:LG_10096154)
Hi @LG_10096154
I would recommend to restart the Windchill server with a temp cleanup
PetrH
Hi @LG_10096154,
Anurag
LG_10096154
(To:LG_10096154)
