Nathan,
Have you found a solution to your problem yet? We are looking for a way to just monitor our Publisher and get notification of failed jobs by email back to an admin. Our publisher is pretty stable, but on the occasion when it does fail a job, it usually fails everything from there on and we don't find out until the next morning.
John Frankovich
The GSI Group LLC
In Reply to Nathan Brown:
We have PDMLink 9.1 and are having issues with publishing and indexing going down. We have a separate workstation that is used to publish our CADD files andthe workstationhas Fast InStream for indexing. The issue is that we do not know when the publisher or indexer go down. Our main concern is the indexer. If files are not being indexed, then older rev files will be found from a global search. Then someone could check out an older rev file and make changes, not knowing there is a newer rev out there. We have stopped using our global search for now. It would be nice to get a notification if the publisher or indexer go down. Otherwise, it could be a week or two later and then we have to reindex the whole vault.
Yes, we did find a way to get notifications if publishing jobs fail or the publisher goes down. It is called the JMX Email Function. TAN138107 explains how to get it set up. This is exactly what we were looking for. JMX also sends me notifications if there are any errors with the Windchill server (ex. memory issues or the MethodServer goes down). Unfortunately, not many people know about JMX. I am having an issue adding multiple people to the JMX email list. I can only get one to work. PTC tech support is looking into it, but we have tried every syntax we can think of and it still only accepts the first email address. The email addresses should be separated by a comma according to the Windchill system admin guide, but TAN138107 shows a period separating the email addresses. There also is a way to go into the Java Console and add email addresses to JMX notifications, but the changes are replaced with the original value the next day. So just put in the one email address and it should work fine.
