Hi Guys,
I want to know if we can merge the attribute values to create a single attribute.
For example, I created a WT part.
I filled out the attribute number 8989, created and added the customer number attribute in WT, and selected it from the drop-down list. I also manually entered the project number for one more attribute. Everything I get into the Number attribute. Is it possible to do it through OIR?
Aj
Take a look at this article, which covers a lot of OIR settings
Article - CS172537 - [Knowledge Hub] Windchill PLM - Object Initialization Rules (OIRs) (ptc.com)
Thanks Rocket,
I discovered that. Now I am looking for the same number and name.
Aj
Hi Guys,
How we can get the number and name should be same using OIR.
Aj
You can use something like this:
<!-- set the name to File Name -->
<AttrValue id="name" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Attr id="number"/>
</AttrValue>
<AttrConstraint id="name" algorithm="com.ptc.core.rule.server.impl.GatherAttributeConstraints">
<Value algorithm="com.ptc.core.rule.server.impl.GetServerAssignedConstraint"/>
<Value algorithm="com.ptc.core.rule.server.impl.GetImmutableConstraint"/>
</AttrConstraint>
Do not forget that the rename operation does not apply the OIR rules.. If someone rename the object where a Number is changed., The name is not automatically changed.
During the rename operation OIR rule is not applied.
PetrH
Could you describe your use case a little more?
Are you using a generated Number, and then you want the Name to match, or something else?
What is your Business Requirement?
1. Do you want the number to be Auto-generated with prefix as intended (Project no+ Customer no+Auto Generated No...etc) ?
2. And then the Part Name should match this?
For the Req 1, it will be a customization
For Req 2, its what the OIR can do (hence no code).
Cheers
Hari
