compare to part structure showing never build problem
  • March 20, 2024
  • 3 replies
  • 1384 views
When i do compare to part structure to an assembly, i see there are some CAD and part with warning saying that they were never build.
when i try to build them up, it is showing an error. see attachment.
could you please help on this?
Br,
sandy
Best answer by Hari_Vara
I think you were trying to build a "Released" part. (Pls note build will create an iteration of the WTPart , which inturn requires it to be in a non-locked state , "Released" is generally a non-editable state (Locked) for a regular user.
CHeers
Hari
Fadel
23-Emerald I
March 20, 2024
issue is with lack of permission can you enable logger wt.access.evaluation.report to Debug and share the logs ?
Buiꓘa
joe_morton
18-Opal
18-Opal
March 20, 2024
You need edit access to the WTParts. Make sure they are not checked out, in an editable state, and that you have edit access to the Context where they are stored.
Hari_Vara16-PearlAnswer
CHeers
Hari
Sandy712-AmethystAuthor
Hi Hari,
You are right, the admin said the same. he helped me to resolve them. thanks...!
Br,
Sandeep C.
