Hello
We are struggling to find form PTC recommendation about how much memory our PDMLink server should have for the size of our PDMLink system and number of users.
We have PDMLink 9.1M050 installed in VMware. We have a vault of about 50GB and about 120 (70% are heavy users)
Is there any recommendation/documentation about how much memory should be available ? I know we can optimize PDMLink to use at best the available memory but nonetheless, it would be good to know if we need 8, 12 , 16 or more GB
Thank you very for any help
This is what I ususally set the sizing on:
Have the same machine for your database with the same memory with a 40% allocation of memory.
Have a separate machine you Windows 2008 R2 64bit multiple CAD worker. This is a must to have a ratio of 1 CAD worker per 10 CAD users. Thus, you need the 2 additional background methodservers for WVS1 and WVS2.
It also depends of the java version, hopefully close to latest is good.
Always use somelike appdynamics.com to monitor and issolate the issue. Saves on consulting and provides constant monitoring. You can use top but you will have to try to load your system at that instant.
Good luck,
Patrick
Hello All,
After 3 plus months of active file storage into a new Windchill 9.1 M060 we are running out of physical space on the server (2tb). The plan is to eventually vault on a SAN, in the meantime what would be the best way for us to prune out unnecessary data?
Thanks in advance, Kathy
